Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Formula Editor
• Formula Overview
Formula Overview
Formulas are an integral part of a data table for the following reasons:
They are stored as part of a column’s information when you save the data table.
You can examine or change them at any time by opening the Formula Editor.
Their values can be linked to, or dependent on, the values in other columns. Their values are automatically recomputed whenever you edit the values in the columns to which the formula is linked.
Their values are locked in the data table so that they cannot be manually edited.
This chapter describes the Formula Editor and shows how to build formulas. For details about each function, see the
Formula Functions Reference topic
Help created on 9/19/2017
