Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Discovering JMP
• Gallery of JMP Graphs
Gallery of
JMP Graphs
Various Graphs and Their Platforms
Here are pictures of many of the graphs that you can create with JMP. Each picture is labeled with the platform used to create it. For more information about the platforms and these and other graphs, see the documentation on the
Help > Books
menu.
Histogram
Analyze > Distribution
Bivariate
Analyze > Fit Y by X
Oneway
Oneway t Test
Logistic
Mosaic Plot
Matched Pairs
Analyze > Specialized Modeling > Matched Pairs
Leverage Plot
Analyze > Fit Model
LS Means Plot
Analyze > Fit Model
MANOVA
Analyze > Fit Model
Partition
Analyze > Predictive Modeling > Partition
Neural Diagram
Analyze > Predictive Modeling > Neural
Actual by Predicted
Analyze > Predictive Modeling > Model Comparison
Nonlinear Fit
Analyze > Specialized Modeling > Nonlinear
Surface Profiler
Analyze > Specialized Modeling > Gaussian Process
Time Series
Analyze > Specialized Modeling > Time Series
Screening
Analyze > Specialized Modeling > Specialized DOE Models > Fit Two Level Screening
FDR pValue Plot
Analyze > Screening > Response Screening
Scatterplot Matrix
Analyze > Multivariate Methods > Multivariate
Dendrogram
Analyze > Clustering > Hierarchical Cluster
Self Organizing Map
Analyze > Clustering > K Means Cluster
Principal Components
Analyze > Multivariate Methods > Principal Components
Canonical Plot
Analyze > Multivariate Methods > Discriminant
Loadings Plot
Analyze > Multivariate Methods > Partial Least Squares
XBar and R Charts
Analyze > Quality and Process > Control Chart Builder
Average Chart
Analyze > Quality and Process > Measurement Systems Analysis
Variability Chart
Analyze > Quality and Process > Variability/Attribute Chart
Goal Plot
Analyze > Quality and Process > Process Capability
Individual Measurement Chart
Moving Range Chart
Analyze > Quality and Process > Control Chart > IR
XBar Chart
Analyze > Quality and Process > Control Chart > XBar
Pareto Plot
Analyze > Quality and Process > Pareto Plot
Ishikawa Chart
Fishbone Chart
Analyze > Quality and Process> Diagram
Compare Distributions
Analyze > Reliability and Survival > Life Distribution
Nonparametric Overlay
Analyze > Reliability and Survival > Fit Life by X
Scatterplot
MCF Plot
Analyze > Reliability and Survival > Recurrence Analysis
Overlay
Analyze > Reliability and Survival > Degradation
Prediction Interval
Analyze > Reliability and Survival > Destructive Degradation
Forecast
Analyze > Reliability and Survival > Reliability Forecast
Piecewise Weibull NHPP
Analyze > Reliability and Survival > Reliability Growth
Reliability Block Diagram
Analyze > Reliability and Survival > Reliability Block Diagram
Failure Plot
Analyze > Reliability and Survival > Survival
Survival Quantiles
Analyze > Reliability and Survival > Fit Parametric Survival
Baseline Survival
Analyze > Reliability and Survival > Fit Proportional Hazards
Mixture Profiler
Analyze > Consumer Research > Categorical
Factor Loading Plot
Analyze > Consumer Research > Factor Analysis
Prediction Profile
Analyze > Consumer Research > Choice
Characteristic Curves
Analyze > Consumer Research > Item Analysis
Multiple Correspondence Analysis
Analyze > Consumer Research > Multiple Correspondence Analysis
Uplift Model
Analyze > Consumer Research > Uplift
Dual Plot
Line Graphs
Graph > Graph Builder
Box Plots
Stacked Bar Chart
Graph > Chart
Pie Chart
Graph > Chart
Needle and Line Chart
Graph > Overlay Plot
Dot and Line Chart
Three Dimensional Scatterplot
Graph > Scatterplot 3D
Contour Plot
Graph > Contour Plot
Bubble Plot
Graph > Bubble Plot
Parallel Plot
Graph > Parallel Plot
Cell Plot
Graph > Cell Plot
Treemap
Graph > Treemap
Scatterplot Matrix
Graph > Scatterplot Matrix
Ternary Plot
Graph > Ternary Plot
Prediction Profiler
Graph > Profiler
Contour Profiler
Graph > Contour Profiler
Surface Plot
Graph > Surface Plot
Mixture Profiler
Graph > Mixture Profiler
Multidimensional Scaling
Analyze > Consumer Research > Multidimensional Scaling
MaxDiff
Analyze > Consumer Research > MaxDiff
Stress Patterns Plot
Analyze > Reliability and Survival > Cumulative Damage
Repairable Systems Simulation
Analyze > Reliability and Survival > Repairable Systems Simulation
Latent Class Analysis
Analyze > Clustering > Latent Class Analysis
Predictor Screening
Analyze > Screening > Predictor Screening
Process Screening
Analyze > Screening > Process Screening
Text Explorer
Analyze > Text Explorer
Help created on 9/19/2017
