Hiding rows does not exclude them from calculations and analyses. In particular, plots that are constructed using observations use the data from hidden rows unless those rows are also excluded.
Rows remain hidden until you highlight the rows and select Hide/Unhide again.
Control Chart Builder. See Control Chart Builder in the Quality and Process Methods book for details.
Graph Builder. The Bar chart, Heat Map, and Pie chart are updated to reflect hidden rows. See Graph Builder in the Essential Graphing book for details.
