You can use Structured Query Language (SQL) statements to control what you import from an external database. When you open a database file in JMP, you are actually sending a SQL statement to the database. By default, this statement gets all files and records in the database table. See Build SQL Queries in Query Builder for details about interactively building queries. See Write SQL Statements to Query a Database for details about writing queries yourself.
Database table names that contain the characters $# -+/%()&|;? are not supported.
