Radio buttons that enable you to select which independent variables are displayed on the x- and y-axes. This feature is useful when you have more than two independent variables.
Locks the z-axis to its current values. This is useful when moving the sliders that are not on an axis.
Selecting a check box activates a grid that is perpendicular to the selected variables axis. The sliders enable you to adjust the placement of each grid. The resolution of each grid can be controlled by adjusting axis settings. Activated X and Y Grids shows a surface with the X and Y grids activated.
