Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Essential Graphing
Parallel Plots
The Parallel Plot
• Interpreting Parallel Plots
To help you interpret parallel plots, compare the parallel plot with a scatterplot. In each of the following figures, the parallel plot appears on the left, and the scatterplot appears on the right.
Strong Positive Correlation
The following relationship shows a strong positive correlation. Notice the coherence of the lines in the parallel plot.
Strong Negative Correlation
A strong negative correlation, by contrast, shows a narrow neck in the parallel plot.
Collinear Groups
Now, consider a case that encompasses both situations: two groups, both strongly collinear. One has a positive slope, the other has a negative slope. In
Collinear Groups: Parallel Plot and Scatterplot
, the positively sloped group is highlighted.
Single Outlier
Finally, consider the case of a single outlier. The parallel plot shows a general coherence among the lines, with a noticeable exception.
Single Outlier: Parallel Plot and Scatterplot
Related Information
Additional Examples of the Parallel Plot Platform
Help created on 9/19/2017
