The Control Panel for the Cytometry.jmp data table is shown in Iterative Clustering Control Panel. You can interactively fit different numbers of clusters or you can specify a range using the Range of Clusters option.
Caution: The total number of nearest neighbors specified is denoted using a small k. This number is not directly connected to the number of clusters, also sometimes denoted with a small k.
Saves the distances from each row to its kth nearest neighbor as new columns in the data table.
Help created on 9/19/2017
