Select Analyze > Fit Model.
Verify that 2 appears in the Degree box.
Click Run.
7.
From the red triangle next to Response weight, select Estimates > Joint Factor Tests.
Note that the test for age has 15 degrees of freedom. This test involves the five parameters for age, the five parameters for age*sex, and the five parameters for height*age. The null hypothesis for this test is that all 15 parameters are zero.
