Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
• K Nearest Neighbors
K Nearest Neighbors
Predict Response Values Using Nearby Observations
The K Nearest Neighbors platform is available only in JMP Pro.
The K Nearest Neighbors platform predicts a response value for a given observation using the responses of the observations in that observation’s local neighborhood. It can be used with a categorical response for classification and with a continuous response for prediction.
K Nearest Neighbors is a nonparametric method that is based on the distance to neighboring observations. Because of this fact, K Nearest Neighbors is able to classify observations using irregular predictor value boundaries. However, the algorithm is sensitive to irrelevant predictors, so selection of predictors can be beneficial before implementing K Nearest Neighbors.
K Nearest Neighbors has been used successfully in many applications, such as classifying satellite imagery and EKG patterns.
Example of the K Nearest Neighbors Platform
Contents
K Nearest Neighbors Platform Overview
Example of K Nearest Neighbors with Categorical Response
Example of K Nearest Neighbors with Continuous Response
Launch the K Nearest Neighbors Platform
The K Nearest Neighbors Report
Continuous Responses
Categorical Responses
K Nearest Neighbors Platform Options
Help created on 9/19/2017
