Use the Knotted Spline Effect option to have JMP fit a segmentation of smooth polynomials to a specified effect. When you select this attribute, a window appears, enabling you to specify the number of knot points. (Knotted splines are only implemented for main-effect continuous terms.)
Select Analyze > Fit Model.
Click Run.
8.
From the report’s red triangle menu, select Estimates > Custom Test.
9.
Click the Add Column button twice to produce a total of three columns.
10.
In the first column, type 1 for age&Knotted@4.5.
11.
In the second column, type 1 for age&Knotted@20.5.
12.
In the third column, type 1 for age&Knotted@36.
13.
Click Done.
The report in Curvature Report appears. The small Prob > F value indicates that there is curvature.
