The launch window is your point of entry into a platform, where you specify the columns to analyze. Anatomy of a Typical JMP Session on Windows shows the Distribution launch window.
Moves selected columns into roles (such as Y, X, and so on.) You cast a column into the role of a variable (like an actor is cast into a role). See Cast Selected Columns into Roles Buttons.
In the Graph Builder window, click the Dialog button on the left or select Redo > Relaunch Analysis to show this panel.
