Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Consumer Research
Choice Models
• Launch the Choice Platform
Launch the Choice platform by selecting
Analyze > Consumer Research > Choice
Your data for the Choice platform can be combined in a single data table or it can reside in two or three separate data tables. When the Choice window opens, the first menu item asks you to specify the Data Format.
One Table, Stacked
For this format, the data are combined into a single data table. There is a row for every profile presented to a subject and an indicator of whether that profile was selected.
For an example of data in the one-table format, see
One Table Format with No Choice
. For details, see
Launch Window for One Table, Stacked
Multiple Tables, Cross-referenced
For this format, the data are stored in two or three separate tables: a Profile Data and Response Data table are required and a Subject Data table is optional. The Choice Launch Window contains three sections, each corresponding to a different data table. You can expand or collapse each section of the launch window, as needed.
For an example of data in the multiple-tables format, see
Multiple Table Format
. For details, see
Launch Window for Multiple Tables, Cross-Referenced
Help created on 9/19/2017
