Launch the Factor Analysis platform by selecting Analyze > Consumer Research > Factor Analysis.
Lists different methods for fitting the model. For details about the methods, see The Multivariate Report in the Multivariate Methods book.
Lists the scaling methods for performing the factor analysis based on Correlations (the same as Principal Components), Covariances, or Unscaled.
