Launch the Gaussian Process platform by selecting Analyze > Specialized Modeling > Gaussian Process.
Gaussian Process Launch Window
Fast GASP
Gaussian restricts the correlation between two points to always be nonzero, no matter the distance between the points.
Cubic allows the correlation between two points to be zero for points that are far enough apart. This method is a generalization of a cubic spline.
Block Size
Help created on 9/19/2017
