Launch the Survival platform by selecting Analyze > Reliability and Survival > Survival.
(Required) Contains the time to event or time to censoring. If you have interval censoring, specify two Y variables, representing the lower and upper limits.
Identifies censored values. Enter the value that identifies censoring in the Censor Code box. This column can contain more than two distinct values under the following conditions:
