Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Learn about JMP
Additional Resources for Learning JMP
• Learn JMP Tips and Tricks
When you first start JMP, you see the Tip of the Day window. This window provides tips for using JMP.
To turn off the Tip of the Day, clear the
Show tips at startup
check box. To view it again, select
Help > Tip of the Day
. Or, you can turn it off using the Preferences window. See the
Using JMP
book for details.
Help created on 9/19/2017
