Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Learn about JMP
Additional Resources for Learning JMP
• Learn about Statistical and JSL Terms
The
Help
menu contains the following indexes:
Statistics Index
Provides definitions of statistical terms.
Scripting Index
Lets you search for information about JSL functions, objects, and display boxes. You can also edit and run sample scripts from the Scripting Index.
Help created on 9/19/2017
