Effect leverage plots are also referred to as partial-regression residual leverage plots (Belsley, Kuh, and Welsch, 1980) or added variable plots (Cook and Weisberg, 1982). Sall (1990) generalized these plots to apply to any linear hypothesis.
vx is the constrained residual minus the unconstrained residual, r0 - r, reflecting information left over once the constraint is applied
These points form the basis for the leverage plot. This construction is illustrated in Construction of Leverage Plot, where the response mean is 0 and slope of the solid line is 1.
These confidence curves give a visual assessment of the significance of the corresponding hypothesis test, illustrated in Comparison of Significance Shown in Leverage Plots:
Borderline: If the t test for the slope parameter is sitting right on the margin of significance, the confidence curve is asymptotic to the horizontal line at the response mean.
Leverage plots mirror this thinking by displaying confidence curves. These are adjusted so that the plots are suitably centered. Denote a point on the x-axis by z. Define the functions
These functions behave in the same fashion as do the confidence curves for simple linear regression:
If the F statistic is equal to the reference value, the confidence functions have the x-axis as an asymptote.
If the F statistic is less than the reference value, the confidence functions do not cross.
Also, it is important that Upper(z) - Lower(z) is a valid confidence interval for the predicted value at z.
