Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
JMP Preferences
• Macintosh OS Settings
Macintosh OS Settings preferences customize settings for Macintosh machines, including the graphics formats and file associations.
Macintosh OS Settings Preferences
Preference
Description
Alternate Image Formats for Clipboard and Drag & Drop
Select one or more graphic formats to use when copying and pasting (or dragging and dropping) graphics from JMP into other applications.
Clipboard Image Scale Factor
Enter the percentage at which you want graphics to appear in other applications.
Image format for RTF
Select the format to use for graphics when you save a JMP report as an RTF file.
RTF Image Scale Factor
Enter the percentage at which you want graphics to appear in RTF documents.
Image format for HTML
Select the format to use for graphics when you save a JMP report as an HTML file.
Help created on 9/19/2017
