A main effects screening design is a design with good balance properties as described by a Chi-square criterion. See Chi-Square Efficiency. Such designs have desirable statistical properties for main effect models.
A measure of the lack of orthogonality evidenced by columns k and l is given by the following expression:
The maximum possible value of χ2, denoted
, is obtained. The chi-square efficiency of a design is defined as follows:
Chi-square efficiency indicates how close χ2 is to zero, relative to a design in which pairs of levels show extreme lack of balance.
