New Table( "Testing Comparisons",
	Add Rows( 4 ),
	New Column( "A",
		Numeric,
		"Continuous",
		Format( "Best", 10 ),
		Set Values( [1, 2, 3, .] )
	New Column( "B", Character, "Nominal", Formula( If( :A, "true", 1, "false" ) ) )
"true"
"true"
"true"
"false"
If(
	:A, "true",
If the value of A is nonmissing and nonzero, the result is "true". This comparison is true for the first three rows.
	1, "false"
If one value is true and another is missing, Or() returns true. (Only one value in an Or() test needs to be true to get a true result.)
If one value is false and another is missing, And() returns false. (Both values in an And() test must be true to get a true result.)
If you know that some values are missing, you can also compare with Is Missing(). The comparison in the preceding example can be rewritten to return "missing" for missing values:
If( :A, "true", Is Missing( :A ), "missing", "false" );
If the missing value could be 0, use the Zero Or Missing() function instead:
Zero Or Missing( A );
Help created on 9/19/2017
