Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Profilers
• Mixture Profiler
Mixture Profiler
Explore Factor Effects Using Ternary Plots
The Mixture Profiler displays response contours on a ternary plot for mixture models, where three or more factors in the model are components (ingredients) in a mixture. The Mixture Profiler is useful for visualizing and optimizing response surfaces resulting from mixture experiments.
Mixture Profiler Example
Contents
Mixture Profiler Overview
Ternary Plot Overview
Ternary Plots with More Than Three Components
Example of the Mixture Profiler
Launch the Mixture Profiler Platform
The Mixture Profiler Report
Factor Settings and Controls
Response Settings and Controls
Mixture Profiler Platform Options
Customizations for the Mixture Profiler
Linear Constraints
Additional Examples of the Mixture Profiler Platform
Mixture Variables with a Process Variable
Multiple Responses with Five Mixture Variables
Help created on 9/19/2017
