Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Generalized Regression Models
• Model Fit Reports
Model Fit Reports
For each Estimation Method and Validation Method that you specify in the Model Launch panel, a report is produced. The report specifies your selected Estimation and Validation methods in its title.
The following reports are presented by default:
Model Summary
Estimation Details (shown only for Lasso, Elastic Net, and Ridge)
Solution Path (shown for all but the Maximum Likelihood Estimation Method and Quantile Regression)
Parameter Estimates for Centered and Scaled Predictors
Parameter Estimates for Original Predictors
Effect Tests
Help created on 9/19/2017
