Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Repairable Systems Simulation
• Options for Block Items
To view settings for the components in a selected design or subsystem, do the following:
To view the Configuration settings for a block shape, select the block shape in the System Diagram.
To view Configuration settings for more than one block shape, select multiple block shapes using the Arrow tool, press Control, and click multiple block shapes.
Help created on 9/19/2017
