Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Basic Analysis
Bivariate Analysis
Fit Orthogonal
• Orthogonal Regression Report
The Orthogonal Regression report shows summary statistics about the orthogonal regression model.
Variable
Gives the names of the variables used to fit the line.
Mean
Gives the mean of each variable.
Std Dev
Gives the standard deviation of each variable.
Variance Ratio
Gives the variance ratio used to fit the line.
Correlation
Gives the correlation between the two variables.
Intercept
Gives the intercept of the fitted line.
Slope
Gives the slope of the fitted line.
LowerCL
Gives the lower confidence limit for the slope.
UpperCL
Gives the upper confidence limit for the slope.
Alpha
Enter the alpha level used in computing the confidence interval.
Related Information
Fitting Menus
Fit Orthogonal
Example Using the Fit Orthogonal Command
Help created on 9/19/2017
