The Map Shape zone assigns geographical boundaries to a map based on variables in the data table. The map shape value determines the x and y axes.
The Color zone applies color based on a variable to geographical shapes.
The Size element scales map shapes according to the size variable, minimizing distortion.
Simple Earth and Detailed Earth maps are installed with JMP.
NASA server provides maps using a WMS to show their most up-to-date maps.
Street Map Service provides street maps. The OpenStreetMap and Open Database License links provide further information on the Street Map Service.
Web Map Service lets you enter the URL for a website that provides maps using the WMS protocol. You can also specify the map layer.
Help created on 9/19/2017
