Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
JMP Reports
Add Images to a Graph or Report
• Paste an Image at the End of a Report
You can also add the graphic to the end of a report window. Copy the graphic from a graphics program onto your computer’s clipboard, display the report window, and select
Edit > Paste
Help created on 9/19/2017
