The Print Algebraic Reliability to the Log Window command prints the reliability formula for the selected system diagram to the Log window.
(Windows only) Select View > Log.
(Macintosh only) Select Window > Log.
Open the exampleRBDcomplete.jsl file that you created.
In the Designs panel, select Computer.
From the Computer red triangle menu select Print Algebraic Reliability to the Log Window.
