Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Extending JMP
Working with R
• R JSL Scriptable Object Interfaces
The R interfaces are also scriptable using an R connection object. A scriptable R connection object can be obtained using the
R Connect()
JSL function.
Help created on 9/19/2017
