Gives the lower 95% confidence limit for the covariance component. For more information, see Confidence Intervals for Variance Components.
Gives the upper 95% confidence limit for the covariance component. For more information, see Confidence Intervals for Variance Components.
Gives the p-value for the test that the covariance parameter is equal to zero. This column appears only when you have selected Unbounded Variance Components in the Fit Model launch window.
