Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Mixed Models
The Fit Mixed Report
• Random Effects Predictions
For each random effect in the model, this report gives an estimate known as the
best linear unbiased predictor
(BLUP), its standard error, and a Wald-based confidence interval.
Estimation of the standard errors requires calculation of the BLUP covariance matrix, which can be time-intensive. If the calculation time is noticeable, a progress bar appears.
Help created on 9/19/2017
