Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Recurrence Analysis
• Recurrence Analysis Platform Options
The following options are included in the platform red triangle menu:
MCF Plot
Toggles on and off the MCF plot.
MCF Confid Limits
Toggles on and off the lines corresponding to the approximate 95% confidence limits of the MCF.
Event Plot
Toggles on and off the Event plot.
Plot MCF Differences
If you have a grouping variable, this option creates a plot of the difference of MCFs, including a 95% confidence interval for that difference. The MCFs are significantly different where the confidence interval lines do not cross the zero line. This option is available only when you specify a grouping variable.
MCF Plot Each Group
produces an MCF plot for each level of the grouping variable. This option is available only when you specify a grouping variable.
This option can be used to get an MCF Plot for each unit if the
Label, System ID
variable is also specified as the
Grouping
variable.
Fit Model
Is used to fit models for the Recurrence Intensity and Cumulative functions. See
Fit Model
Help created on 9/19/2017
