Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
JMP Reports
Red Triangle Options in a Report
• Redo Menus
Redo Menus
After performing an analysis, you might want to run the analysis again using different options or variables. You might also want to perform the analysis again if data in the data table have changed. The Redo red triangle menus provide these options.
Column Switcher
Lets you interactively exchange one column for another on a graph. See
Column Switcher
Redo Analysis
Duplicates the analysis based on the previous launch window settings. The analysis appears in a new report window. This option is helpful if the data have changed.
Relaunch Analysis
Opens the launch window and recalls the settings used to create the report.
Automatic Recalc
Automatically updates analyses and graphics when data table values change. See
Automatic Recalc
Help created on 9/19/2017
