The Reliability Test Plan feature computes required sample sizes, censor times, or precision, for estimating failure times and failure probabilities.
To launch the Reliability Test Plan calculator, select DOE > Design Diagnostics > Sample Size and Power, and then select Reliability Test Plan. Reliability Test Plan Window shows the Reliability Test Plan window.
Interval Ratio is sqrt(U/L), the square root of the ratio of the upper and lower limits.
Two-sided Interval Absolute Width is U-L, the difference of the upper and lower limits.
Lower One-sided Interval Absolute Width is T-L, the true value minus the lower limit.
Two-sided Interval Relative Width is (U-L)/T, the difference between the upper and lower limits, divided by the true value.
Lower One-sided Interval Relative Width is (T-L)/T, the difference between the true value and the lower limit, divided by the true value.
After the Continue button is clicked, two additional statistics are shown:
Select Reliability Test Plan.
Select Weibull from the Distribution list.
6.
Select Two-sided Interval Absolute Width from the Precision Measure list.
7.
Select Estimate time associated with specified failure probability.
8.
9.
Enter 2500 for Censor Time.
10.
Enter 200 for Precision.
11.
