Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Time Series Analysis
• Reports
Reports
Difference Report
The Difference Report contains graphs of the autocorrelations and partial autocorrelations of the differenced series. These graphs can be used to determine whether the differenced series is stationary.
The ARIMA and Seasonal ARIMA models that are available in the Time Series platform accommodate a differencing operation. In a two step process, these models first difference the time series according to the differencing operation, and then fit the differenced series. The Difference option is a useful preprocessing tool for determining the order of differencing to specify for the ARIMA model.
The Difference red triangle menu contains the following options:
Graph
Shows a submenu of options to control the appearance of the differenced series plot. See
Time Series Platform Options
Autocorrelation
Shows or hides the autocorrelation of the differenced series.
Partial Autocorrelation
Shows or hides the partial autocorrelations of the differenced series.
Variogram
Shows or hides the variogram of the differenced series.
Save
Saves a new column that contains the values in the differenced series to the original data table. Some of the leading elements are lost in the differencing process. They are represented as missing values in the saved Difference column.
Help created on 9/19/2017
