Denote the linear mixed model by E[Y|γ] = Xβ + Zγ. Here
is the vector of fixed effect coefficients and γ is the vector of random effect coefficients. The marginal residuals are the residuals from the fixed effects part of the predictive model:
Shows the residuals plotted against the predicted values of Y. You typically want to see the residual values scattered randomly about zero.
