Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Profilers
Custom Profiler
The Custom Profiler Report
• Response Settings and Controls
Response
The list of one or more responses.
Current Y
The predicted response based on the current X settings. This value updates as the factor settings are changed.
Lo Limit
Enables you to set a lower limit for your response.
High Limit
Enables you to set an upper limit for your response.
Benchmark
A saved predicted value of the response. Initially, this value is set to the predicted value when all responses are at their mean value.
Reset Benchmark
Updates the benchmark value to the current predicted value.
Help created on 9/19/2017
