Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Enter and Edit Data
• Restructure Data
Restructure Data
This section describes how to restructure and reformat your data. Change your data by using either the Utilities menu options, creating a new formula column, or by creating a temporary transform column.
To restructure a column or multiple columns, select
Cols > Utilities
and choose from the list of options. At least one column must be selected to enable these menu options.
Help created on 9/19/2017
