The control limits or limit parameter values can be either in a JMP data table, referred to as the Limits Table, or stored as a column property in the process column. You can retrieve the Limits Table with the Get Limits option on the Control Chart Builder red triangle menu.
The Control Chart Builder identifies the appropriate limits from keywords in the _LimitsKey column. A list of limit keywords and their associated control chart is shown in Limits Table Keys with Appropriate Charts and Meanings.
Except for _Sample Size, any needed values not specified are estimated from the data.
All except Control Chart Builder
X-, R-, S-, IM, MR
c-, u-
np-, p-
_LCL, _UCL
X-, IM, p-, np-, c-, u-, g-, t-
R-, MR
_LCLR, _UCLR
R-, MR
_AvgS, _LCLS, _UCLS
S-Chart
Help created on 9/19/2017
