Orthogonal Rotation Methods lists the available orthogonal (that is, uncorrelated) rotation methods.
Note: The default p value is 1 unless specified otherwise in the GAMMA = option. For additional information about orthomax weight, see the SAS documentation, “Simplicity Functions for Rotations.”
Oblique Rotation Methods lists the available oblique (that is, correlated) rotation methods.
ROTATE=OBLIMIN, where the default p value is zero, unless specified otherwise in the TAU= option.
