Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Essential Graphing
• Scatterplot Matrix
Scatterplot Matrix
View Multiple Bivariate Relationships Simultaneously
Using the Scatterplot Matrix platform, you can assess the relationships between multiple variables simultaneously. A scatterplot matrix is an ordered collection of bivariate graphs. For further analysis, you can customize the scatterplots with density ellipses for all of your data, or for only groups of your data.
Example of a Scatterplot Matrix
Contents
Launch the Scatterplot Matrix Platform
Change the Matrix Format
The Scatterplot Matrix Window
Scatterplot Matrix Platform Options
Example Using a Grouping Variable
Create a Grouping Variable
Help created on 9/19/2017
