Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Get Started
Manage JMP Files and Open Windows
• Search for Recently Opened Files on Windows
Recently opened files are listed in the Home Window. You can also search for recently opened files from any JMP window.
Select
File > Quick Open
or press Alt, Shift, and then O to open the Filter box and enter your search term. This option also lets you view the path of the file. Press Esc or click the X button to close the window after you type a search term.
Help created on 9/19/2017
