Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Consumer Research
Multiple Correspondence Analysis
Multiple Correspondence Analysis Platform Options
• Show Partial Contributions to Inertia
Shows the Partial Contributions to Inertia for the Column Points table or the Partial Contributions to Inertia for the Row and Column Points tables. Also shows the Plot of Partial Contributions to Inertia for the Column Points. This is a bar chart that shows, for each level of each Y variable, its partial contributions to each of the dimensions shown in the table.
X
Lists the columns specified as X, Factor variables.
Y
Lists the columns specified as Y, Response variables.
Category
Lists the levels of the X or Y variables.
Dimension 1, Dimension 2, Dimension 3
Lists the contribution of the response or factor level to the inertia of the indicated dimension. By default, the tables show columns for up to the first three dimensions. Additional columns are hidden. To show these optional columns, right-click on a table and select the dimension columns from the
Columns
submenu.
Each level of each response contributes to the inertia of each dimension. The partial contributions within each dimension sum to 1.
Note:
If there are columns specified as X, Factor variables, the Partial Contributions to Inertia report displays tables of both X and Y with the same report headings. See
Help created on 9/19/2017
