When the Source is All Users, change the customization set to All users to hide the item from all users.
When the Source is JMP Add-In, change the customization set to JMP Add-In followed by the name of the add-in. The item is shown or hidden in all sets that include the selected JMP add-in.
If you do not change the customization set, the item is shown or hidden only in the currently selected set. See Change Customization Sets for details about customization sets.
Note: To quickly hide or show toolbars for the current user, select or deselect them from the View > Toolbars list.
Select View > Customize > Menus and Toolbars.
Select or deselect Hidden in the General properties. See Step 2: Specify the Caption and Internal Name for details about the General properties.
Click Save to save your changes.
