Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Scripting Guide
Scripting Tools
Working with the Log
• Show the Log in the Script Window
You can view the log inside the script window by right-clicking and selecting
Show Embedded Log
. This option makes it easy to edit and run a script, quickly see the results of your changes, and then continue to develop the script.
The embedded log always appears in the Scripting Index script window but is not available in Application Builder and the Debugger.
Help created on 9/19/2017
