This example uses the Analgesics.jmp data table, which contains data on pain measurements taken on patients using three different drugs.
Does the variability in the pain control given by each drug differ? A drug with high variability would not be as reliable as a drug with low variability.
Click OK.
6.
From the red triangle menu, select Display Options > Box Plots.
The box plots in Side-by-Side Box Plots show these answers:
