The simplex lattice design is a space filling design that creates a triangular grid of runs. The design is the set of blends where the factors’ values are i / m, where i varies from 0 to m and the sum of the factors is 1. For a three-level design, a factor can be set at 0, 0.33, 0.66, or 1.
Select DOE > Classical > Mixture Design.
Click Continue.
Click Simplex Lattice to generate the design.
Click Make Table.
6.
From the design table, select Graph >Ternary Plot.
7.
