Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Basic Analysis
• Simulate
Simulate
Answer Challenging Questions with Parametric Resampling
The Simulate platform is available only in JMP Pro.
The Simulate feature provides powerful parametric and nonparametric simulation capability. Use Simulate to do the following:
Expand on the bootstrap to provide parametric bootstrapping.
Obtain power calculations in nonstandard situations.
Approximate the distribution of statistics, such as predicted values, and confidence intervals, in nonstandard situations.
Conduct permutation tests.
Explore the effect of assumptions about predictors on models.
Explore various “what if” scenarios relative to your models.
Evaluate new or existing statistical methods.
The Simulate option is available in many reports, including all of those that support Bootstrap. To access the Simulate option, right-click in a report.
Power Analysis Using Simulate
Contents
Overview of Simulate
Examples That Use Simulate
Construct an Accurate Confidence Interval for Variance Components
Conduct a Permutation Test
Explore Retaining a Factor in Generalized Regression
Conduct Prospective Power Analysis for a Nonlinear Model
Launch the Simulate Window
The Simulate Window
The Simulate Results Table
Simulation Results Report
Simulated Power Report
Help created on 9/19/2017
