Shows the defect rate as an isolated function of the parameters of each factor’s distribution. This command is enabled when the Defect Profiler is launched. For more information see Defect Parametric Profiler.
Is a hidden option accessible by holding down the Shift key before clicking the Simulator red triangle menu. This option enables you to specify the number of strata in Normal Weighted. For more information also see Statistical Details for the Simulator.
Runs a designed simulation experiment on the locations of the factor distributions. A window appears, allowing you to specify the number of design points, the portion of the factor space to be used in the experiment, and which factors to include in the experiment. For factors not included in the experiment, the current value shown in the Profiler is the one used in the experiment. For more information, see Simulation Experiment.
