Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Essential Graphing
Bubble Plots
Launch the Bubble Plot Platform
• Specifying a Time Variable
Maintains separate coordinates, sizes, and colors for each unique time period. The bubble plot shows these values for a single time period. For example, if the
Time
column contains years, the bubble plot is updated to show data by each year.
To move the time label on the plot, click and drag the label.
If data is missing within a time period, the value is linearly interpolated. If data is missing for the first or last time period, the value is not estimated, but left as missing.
Related Information
Control Animation for Dynamic Bubble Plots
Example of Specifying Only a Time Variable
Help created on 9/19/2017
